saevelland
04-27-2008, 03:07 PM
The driver side power window works sometimes and goes out randomly. When not working the relay clicks. And it doesnt line up right. Any one know what the problem is.
Drive Power window works sometimessaevelland 04-27-2008, 03:07 PM The driver side power window works sometimes and goes out randomly. When not working the relay clicks. And it doesnt line up right. Any one know what the problem is. shoebox 04-27-2008, 03:32 PM Could be the window motor or something in the window mechanism that is binding or broken("doesn't line up right"). Probably going to need some inspection with the inner door panel removed. saevelland 04-27-2008, 03:37 PM we all ready tool evey thing off some of the fiberglass wher the window motor atached to is gone so the motor isnt lined up right. I dont know how i would go about fixing the fiber glass. shoebox 04-27-2008, 05:32 PM Fiberglass patch kit. :) saevelland 04-27-2008, 11:09 PM will do. And i figured out it wasnt a fuse. Mustve been the motor. Any suggestions on what brand to buy for repair kits? SpeedDemon02SS 04-28-2008, 06:45 AM autozome is cheap, about $60 if i remember correctly. And they have a lifetime warrenty. dealership runs around 170, but you can also try gmpartsdirect.com if you want factory. I just checked, it is 87 plus shipping. but no lifetime warrenty. saevelland 04-28-2008, 06:16 PM For the window motor? Red93Camaro 04-28-2008, 06:21 PM I have the same problem! when I press the button on the the door to have my passenger side window roll down...sometimes it works sometimes it doesnt...Is it the switch? or the motor? I know on the drivers side the window goes up really slow...and stops half way...then I have to wait and Do it again to get it down completely. Any help here? ss.slp.ls1 04-28-2008, 07:48 PM I have the same problem! when I press the button on the the door to have my passenger side window roll down...sometimes it works sometimes it doesnt...Is it the switch? or the motor? I know on the drivers side the window goes up really slow...and stops half way...then I have to wait and Do it again to get it down completely. Any help here? Sounds like you need a new motor. ;) Red93Camaro 04-28-2008, 08:20 PM Sounds like you need a new motor. ;) Thats it? nice, Thats not a problem at all...I thought it was all electronic buttons and stuff...:) autotrix 04-30-2008, 12:15 PM I have the same problem! when I press the button on the the door to have my passenger side window roll down...sometimes it works sometimes it doesnt...Is it the switch? or the motor? I know on the drivers side the window goes up really slow...and stops half way...then I have to wait and Do it again to get it down completely. Any help here? I have seen cracked driver side window switch causing intermittent electrical issues like what you are experiencing. I would check voltage at the passenger window while pressing the switch and wiggling it and see if it cuts out. 9 out of 10 times it is just a motor, but you never know! Keep us in mind when replacing that passenger side window motor. :D SpeedDemon02SS 04-30-2008, 12:24 PM Yes, that was the price of the window motor. Also, look at what autotrix said, I had that issue too. The cover to the switch was cracked on one side, making the connection a bit intermitten. | ||
