a4z28
04-22-2008, 09:20 PM
will these rims be a direct bolt on or do i need spacers cause it is a lt1 car? thanks
10 spoke ss rims on a 95 za4z28 04-22-2008, 09:20 PM will these rims be a direct bolt on or do i need spacers cause it is a lt1 car? thanks TeamingTealZ28 04-23-2008, 02:20 AM Fronts will work with no problem. The rears might need to be grinded down a little bit. a4z28 04-23-2008, 06:39 PM Anyone knows for sure. JAB 04-23-2008, 06:52 PM The wheels fit in the fender wells the same as they do on the newer cars. The only difference is the rear hubs on the LT1 cars are a tiny bit bigger and as such need to be sanded or the inside of the needs to be, otherwise they won't fit over. joe_95z28 04-27-2008, 03:48 PM As stated they fit as they would on the newer cars. You will need to grind/sand hubs on the rear rims. As far as rubbing, I have 275's all around and no problem. http://www.camaroz28.com/forums/showthread.php?t=596366 This is a post about the same topic (I posted at the end) and I have my car domain site with a little bit of information on the grinding required. It will take less than a minute on a dremel per side. So it is not a big job. | ||
