flaminfoster
04-21-2008, 10:59 PM
I have a 92 camaro 305 TPI and getting a tdc 43. I have done some research and alot of people have had this problem. Has anyone fixed it? If so what did you do to fix it?
Has anyone fixed a code 43?flaminfoster 04-21-2008, 10:59 PM I have a 92 camaro 305 TPI and getting a tdc 43. I have done some research and alot of people have had this problem. Has anyone fixed it? If so what did you do to fix it? Kevin91Z 04-27-2008, 05:03 PM Code 43 is a knock sensor problem. Either the wire has come off the knock sensor on the bottom passenger side, or the knock sensor has failed somehow. 87BlackZ 05-01-2008, 06:59 PM I had this issue before and my motor went bad not too far in the future, make sure it is the sensor and you aren't getting any rod knock. I would also check your compression as well. Since you are going to get a bunch of coolant out of the Knock Sensor hole, you might as well do a coolant flush as well. Good luck! | ||
