lordmetalz28
04-21-2008, 10:44 PM
what can i wire a 12v light to,, i need something that comes on and stays on when the car is running as in always powered up,, and shuts off when the car is not running??? any help* appreciated????
wiring info neededlordmetalz28 04-21-2008, 10:44 PM what can i wire a 12v light to,, i need something that comes on and stays on when the car is running as in always powered up,, and shuts off when the car is not running??? any help* appreciated???? Gord's Green Z28 04-21-2008, 11:07 PM 12 volt ignition wire in the back of your radio wiring. I hooked into that for my radar detector. http://www.installdr.com/harnesses/GM-Wiring.pdf lordmetalz28 04-21-2008, 11:52 PM what color indicates that hot ignition wire????? Tex95Z 04-22-2008, 12:25 AM take a multi meter, find out what is hot with key on engine off, constant, ect. you should look for an orange , yellow or red. Gord's Green Z28 04-22-2008, 01:01 AM Did you click on my link? Tap into the yellow wire going into the back of your radio. | ||
