jchevy 04-13-2008, 07:47 PM Thought I would give it a shot on my old motor before I get my rebuild done. A lot of local guys run it without problems. And I had plenty of injector left with Gas.
So far it seems to run pretty good. Added 20% fuel everywhere and had to richen it up WOT some more. I also Added 2* of timing everywhere.
I had issues with KR at 4000 RPM before that are now gone. Ive added 3 degrees more timing in so far for WOT runs and it has not returned,:)
As far as converting fuel lines goes I havent changed anything. The only thing I am planning on changing is the rubber lines in the tank for my dual pumps. Some say the whole system needs to be upgraded, others say it will be fine. Guess I will find out!
1982z28with18s 04-15-2008, 03:29 AM I was really close to switching to E85, but since I'll daily drive the car and the closest station to me is 13 miles it just wasn't a feasable idea anymore. Here soon, I will run a second fuel system with pure 110 in it so I can turn it up on the fly if need be.
jchevy 04-15-2008, 09:38 AM Yeah, If I had to daily drive it I wouldnt be running it. But I have to stations that carry it within 8 miles of my house and about 10 more scattered around town, so its not to tough to get here.
Tricked-Out-Toy 04-15-2008, 01:47 PM SWEET, as soon as a station opens up near me im all over it! I would say in the next eyar ill have E85.
Have you noticed the power increase? did you dyno it before on gas? Ive seen alot of the boosted guys switching over and loving it, some are saying its better than the race gas they were using.....
turnerup 04-16-2008, 04:31 PM did you run faster with the e85 fuel?
thanks,
Scott
turnerup 04-16-2008, 04:37 PM did you run faster with the e85 fuel?
thanks,
Scott
mdacton 04-16-2008, 05:38 PM I wish they had it around me.....
I would try it
jchevy 04-17-2008, 09:47 PM I dont have any track times with the e85 and the car was never really tuned with gasoline. I had a knock issure with gas so I decided to give the e85 a try.
I am showing 30* timing at WOT with no knock now:)
c0rey 04-17-2008, 11:19 PM Im thinking about switching over to it. I have more 85 stations then I do 93. You should send me a tune for 6 psi on 42.5 injectors, low timing!:bow: Keep us updated my car is getting a new engine at the moment.
jchevy 04-18-2008, 09:45 AM Im running a speed density open loop tune, the tune probably wouldnt work on any other motor. I can send it to you to take a look at if you want though, but I dont think it would work in your car. Im still working on it though.
c0rey 04-18-2008, 09:55 AM Shoot it to my email.
prochargedz@gmail.com
blkchevyz 04-18-2008, 02:33 PM are the 60# injectors cutting for you? i converted my friends n/a high compression 383 over (well i did the tuning) and his 42lb were maxed out. we had to bump the fuel pressure up to bring down the duty cycle.
jchevy 04-18-2008, 03:04 PM My injectors are about 65% duty cycle up from 50% on gasoline. I am running dual walbro pumps to keep up with them.
c0rey 05-02-2008, 01:32 PM Still going good?:D
jchevy 05-03-2008, 01:08 PM Still running good. I might be imagining things but I think the car is running 5-10* cooler.
IROCThisZ28ForLife 05-04-2008, 11:55 AM i wanted to try this, but all the stations around me are city owned (private), and on top of that the only one that isnt is 2 tolls, and a lot of driving away
c0rey 05-06-2008, 12:19 AM So your injec duty cycle is at 65% at 5 psi? Trying to figure out how big of injectors I need to run 10-15 psi. :)
jchevy 05-06-2008, 01:04 AM Im going to be running 15 psi sooner or later. My block and rotating assembly are at the machine shop now. Im not sure when I will put it in though.
But yeah, 65% at 5 psi and FPR set at 43 psi
c0rey 05-06-2008, 07:32 AM Are you planning bigger injectors or adjustable fpr?
kgkern01 05-31-2008, 04:26 PM Doesn't the E85 also clean out your fuel system and combustion chambers? If so, I wouldn't mind running a tank per month with a tune for 25% more fuel and 2*+ timing thru the car to keep everything cleaned out.
