cause4panic
04-11-2008, 02:19 PM
Ok so the turbo, intercooler, v band, and two reducers that i need are ordered.
Will running 5-9psi(max max max) on stock valve springs produce any float etc? Any stability issues?
I have zero experiance with pushrod motors on boost.
jsetzer
04-11-2008, 02:24 PM
How many miles are on those stock ones?
Answer is maybe. 9# they "should" hold if they are not tired and staying in the stock rpm range.
cause4panic
04-11-2008, 02:31 PM
Stock rpm range, prolly 110k on the motor. but It seems very healthy. Completly stock!!!!!
jsetzer
04-11-2008, 02:58 PM
If you are on a budget it can't really hurt to try. Plenty of people have done it in the past. 5psi should be fine, above that may be hit or miss.
cause4panic
04-11-2008, 03:49 PM
So i would know they are floating by a sharp drop in power at X rpm correct?
jsetzer
04-11-2008, 05:17 PM
Pretty much. The times I have seen it its like hitting a rev limit. On the dyno it would be a really sharp dive.
