Anyone help on the biggest tires to fit on C5 wheels?
pat35
04-10-2008, 08:50 PM
i just got a set of c5 rims 17/8.5 in front and 18/9.5 in rear.they are true c5 rims i think I'm right on the width. Does anyone know the widest tires i can put on them? I believe they make 305 / 45/18 i think woud they fit on the rear i mean and wear good or is 185 or 175 better and on the 17 which size is best? i am looking at nitows 555, what others do you recommend? any help woud be appreciated.
Pat
ttop1986
04-10-2008, 10:21 PM
I have 2001 vette wheels on my car. The rears are 275's and had slight rubbing issues. I had to hammer inside the wheel well a little bit, and it's ok. I wouldn't go with anything over 275's for that wheel. And the front, I have 245's. I wouldn't go wider on the front because then you would have the front oversized, but the back wouldn't be. I think it would look funny.
KajunKadillac
04-10-2008, 11:53 PM
I have 2003 C5 Rims on my camaro and im running 275/40ZR18 on the rear and 225/45ZR17 on the front. got a new set of ZR rated Allseason tires for front and rear for $690 at my local tire store.
Injuneer
04-11-2008, 12:40 PM
The objective is to come close to matching the outside diameter of your new tires to the stock tire diameter. Your stockers were either 235/55-16 at 26.1" (base V8 tires) or 245/50-16 at 25.7" (Z-rated RPO "QLC" option).
A 305/45-18 will not fit correctly on a 9.5" wide wheel - at least according to the tire manufacturers (M/T ET Street Drag Radial or Nitto 555R is OK). Even if it would fit on the rim, its a 28.8" diameter tire, and would not fit in your rear wheel wells without major surgery/body work. And then it would make your 3.73 gears feel like they are 3.32's (if there was such a size).
For the 17x8.5" wheel:
- 245/45-17 (25.7")
- 255/45-17 (26.1")
For the 18x9.5" wheel:
- 275/35-18 (25.6")
- 285/35-18 (25.9")
The 275/40-18 is a Corvette size, with a 26.7" diameter. The 225/45-18 is a 26.0" tire, and a bit narrow for an 8.5" wide wheel.
Finally.... we have a "Wheels and Tires" forum, so I'll move your post there.
pat35
04-11-2008, 09:48 PM
thank you i did not see the tire section.. so 285/35/18 would fit in the wheel wells and need minor moding to lip on wheel well. Fred, I am looking at the nitows 555r a few others said go with the bf good kdw-2's how do they compare to the 555r? They are 50 -60 dollars more a piece. Do they make a m/t et street in the 175 or185/18 i didnt see them when I looked. I also only found the 555r in 40 not 35, now I get cost at work for tires and we were busy so couldnt do much searching.
69z-28
04-11-2008, 11:09 PM
thanl you i did not see the tire secon . so 285/35/18 wood fit in the weel wels and ned minor moding to lip.injuneer i am locking at the nitows 555r a fue others sead go with the bf good kdw-2's how do they compar to the 555r they are 50 to60 dolers more a pce .do they make a m/t et street in the 175 or185/18 i dident see them wen i locked. i also only found the 555r in 40 not 35 now i get cost at work for tirers and we wer bise so coudent do much serching
dude, if you're looking for help, learn to type....
pat35
04-11-2008, 11:22 PM
sare i have deslexia
pat35
04-11-2008, 11:57 PM
Hey guys, real sorry about the spelling on my last post, I have dyslexia, and when my girlfriend read it she gave me ______! Sometimes I forget how bad my spelling is.
Once again, sorry, and I will make sure she checks it before I send it.
69z-28
04-12-2008, 07:41 AM
well now, dont i feel like a dick. sorry but there's a lot of people here who are just too lazy to type properly. but when it's easier to understand and read things, it's also a lot easier to give meaningful and useful help.
Injuneer
04-12-2008, 12:07 PM
I think this illustrates why its not a good idea to jump on people for spelling, sentence structure or punctuation. I was guilty of this myself from time to time, but I've spent a lot of time working with pat35 on some data logs and other items, and its opened my eyes. I was truly not aware of the magnitude of the problems that dyslexia can present. We've added a "Please excuse....." to his signature, so people can hopefully be more understanding.
Injuneer
04-12-2008, 12:29 PM
As far as tire selections:
285/35-18 should not require any mods to the fender lip or the inner fenders. The 65mm offset of the C5 wheel will put it a bit "deep" in the wheel well, but there should still be 1/4" more clearance than we get with the 17x11 50mm wheels.
Appears you are looking for drag radials.
Mickey Thompson:
265/40-18 (26.5") fits 9.0-10.0" wheel
305/35-18 (26.4") fits 10.0-12.0" wheel - might fit on a 9.5, and bulge a little
Nitto:
305/35-18 (26.4") fits 10.0-12.0" wheel - Nittos are know for being on the "narrow" side, so might fit.
BF Goodrich:
275/35-18 (25.6") 9.0-11.0" wheel
295/35-18 (26.2") 10.0-12.0" wheel
I couldn't find any Goodyear DR's in 18"
pat35
04-13-2008, 12:21 AM
i nead a set of drag radials that work good on the street for later.but right now i need street tires to fit these rims front and rear. i think iam going with the nitows 555r. i get a good prise threw our other shop.the 555r are the ons i ned right? i see they have other 555 listed on line. thank you very much injuneer.you bent over backwars to help and anser a lot of my stuped questens.
