700r4 won't go in all the way
Old Apr 9, 2008 | 09:04 PM
camaro_tim81's Avatar
i am doing a 700r4 swap and the tranny i just got wont go in all the way does it need to be line up with any thing? thay are both the same tranny what is stoping it ? its a inch a way from bolting in plz help me thank you
Old Apr 9, 2008 | 09:19 PM
Performabuilt's Avatar
Supporting Vendor
You dont hve the converter fully inserted into the pump , You are not trying to put the trans up with converter allready mounted are you
Old Apr 9, 2008 | 09:23 PM
yes converter allready mounted.. do i need to take that off then put it in ?
Old Apr 9, 2008 | 09:26 PM
marshall93z's Avatar
Yes! Put it on the tranny first. ALL THE WAY on the tranny.
I just had a problem today, also. Converter wouldn't fit inside the crank!
Had to grind some from the ID of the crank.
Old Apr 9, 2008 | 09:50 PM
ok...
68camaroboltz
Oct 5, 2015 01:46 PM
Hal Fisher
Sep 30, 2015 09:03 PM
KYWes
Sep 26, 2015 08:49 AM
Jake Bialke
Sep 24, 2015 11:31 AM
92_RS_305
Sep 8, 2015 07:47 PM
