Look what I found in my turbo
jsetzer
04-07-2008, 10:48 PM
Now I realize why my exhaust was so hot, my numbers low, and about 98% of my issues.
Its simply amazing.
Do you see the problem here?
http://inlinethumb06.webshots.com/39749/2743940100100765377S600x600Q85.jpg (http://good-times.webshots.com/photo/2743940100100765377DZrbqt)
How about now?
http://inlinethumb42.webshots.com/41129/2724168890100765377S600x600Q85.jpg (http://good-times.webshots.com/photo/2724168890100765377YQVLXN)
Well theres your trouble right there.
http://inlinethumb45.webshots.com/39276/2347023040100765377S600x600Q85.jpg (http://good-times.webshots.com/photo/2347023040100765377bTYpiz)
Last shot is for a size reference.
http://inlinethumb01.webshots.com/11264/2623725580100765377S600x600Q85.jpg (http://good-times.webshots.com/photo/2623725580100765377PbstYk)
How it got in there, or in my exhaust and then there I have no idea. Maybe it was in the turbo before I got it, maybe it fell in while we were building the hot side @ 6 in the morning with beer and bubble gum. Its a piece of 2.5" mild steel tube, folded in half, and I guess from heat and pressure had been slowly shaped to fit the inside of the the snail shell on the turbine housing. By some miracle the blades never touched it. In fact my turbo is as tight as it was brand new. Got the rust off and she looks good.
Look back at the first picture you can see that the metal piece is @ half way around the snail, so it was blocking off a good half of the flow through the turbo.
More to come later.
FireChicken1995
04-07-2008, 10:52 PM
so thats how yall are tuning your turbo cars down....
97s10ondubs
04-07-2008, 11:04 PM
Holy **** lol, I cant believe you didnt trash the blades.
jsetzer
04-07-2008, 11:08 PM
Would have been a good excuse to step up to a 76 :)
They look perfect. The only markings on the piece of metal are from it sliding around inside the snail.
Sparkz28ss
04-07-2008, 11:22 PM
holy crap.... that is crazy!!!
lol... lucky you found it
Lisa33
04-08-2008, 01:51 AM
Fantastic, widh that kind of luck, go buy youreself sa lottery ticket :)
OneFlyn95z28
04-08-2008, 02:47 AM
Damn!!!!
RealQuick
04-08-2008, 09:57 AM
Never seen that before!
SantaCruz163
04-08-2008, 10:05 PM
I can't believe that hunk of steel didn't destroy the turbine wheel! :eek::eek::eek:
GMRL
04-09-2008, 12:13 AM
Is that your MP T70? Be sure to post that in the turbomustangs.com MP survival thread.
slomarao
04-09-2008, 12:56 AM
well i guess building motors and drinking all nite arent the two best activities to pair together? Your one lucky sob.
jsetzer
04-09-2008, 08:40 AM
Good catch, will do.
I can't wait to get it back together now, should be a different car. I warped a flange (wonder where the extra heat came from :rolleyes:) so I am redoing my driver side manifold.
c0rey
04-09-2008, 03:22 PM
Get that thing back on the dyno.
jsetzer
04-09-2008, 04:16 PM
Gots to pay taxes and get a car tag (taxes again) but I hope to soon. Picked up a small bonus at work and should have some overtime on this check.
Redoing my trigger setup and my hot side. Also going to redo some wiring while I'm under there. And try to find an oil leak. Damn projects.
engineermike
04-09-2008, 10:36 PM
I had something similar happen. You know the washers that seal the water tube to the back of the cylinder heads? Somehow (actually, I know exactly how), one of those wound up in my snail. The car really woke up when I pulled it out, so you can expect a big power gain now!
Mike
jsetzer
05-08-2008, 10:37 AM
Spent the past week redoing the whole thing. New hotside + exhaust and now without pieces of crap in the turbine.
I only limped it around the block last night because it was wet out, dark, dont trust the brakes yet (abs delete), etc etc. But so far it seems to run MUCH better.
No glowing manifolds, boost comes on instantly, snaps right to my wastegate spring setting, sounds much better, responds to tuning adjustments better (idle so far at least)
Also redid my crank trigger. Its now much cleaner. Timing dialed right in where I wanted it.
I hope to get out and drive it some after work today.
c0rey
05-08-2008, 09:06 PM
Congrats get some REAL numbers outta it now.
reamo04
05-08-2008, 11:48 PM
let us know how she does. Im getting mine out saturday for some little street fun.
What psi are you running? I forgot
jsetzer
05-09-2008, 09:25 AM
Well hell I don't know at this point.
Yesterday I saw as high as 14 psi but it felt like a turd. First night it ran great. I am getting so sick of this.
c0rey
05-09-2008, 10:56 AM
Lt1 syndrome.:p
IROCThisZ28ForLife
05-10-2008, 10:11 AM
haha well at least you caught that metal chunk before anything happened
