TransAm-Z
04-07-2008, 08:43 PM
I have been able to log my LM-1 wideband through using the A/C pressure sensor and DataMaster. The problem I am having is the noise that shows up logging this way. The LM-1 shows a flat line reading (Say 14.5) and Datamaster shows the reading jumping back and forth like 13.8-15.2. So the signal output can only be averaged becuase of this noise. I have recalibrated the LM-1 to read from 0-5 volts from 10.0-AFR to 15.0-AFR to try and narrow the noise, but it didn't help that much. I have also tested this with the car shut off and I get the same noise!
Has anyone else seen this problem? Is there another sensor that I can use to log? Or could this be an issue with running the LM-1 using the Cigartte lighter? Anyone have any suggestions?
