new cam in 1991 305 RS
i am replacing the stock heads and manifold with a pair of vortec heads and a vortec manifold and i am going to be also doing a cam change at the same time what would be a good roller cam to complement the new heads and manifold
i want one with a lopey idle
was looking at a comp cam or a gm performance parts cam
3in flowmaster american thunder exhaust
GM - LT4 HOT
COMP - XE274HR
Every one is going to tell you they are too big, but that is because they have been diluted into believing this by to many people saying the computer won't except it. Well it will, and I have drove the cars with them in TPI and TBI set ups.
Martin
COMP - XE274HR
Martin
Remember that if you go with anything over ~.470 lift with the vortec heads that you'll need to have work done to them to have them accept the higher lift cams. The stock springs suck ***. My recommendations would be a LT1 cam if you dont have any money like I did, or a ZZ4 cam if you can work with the computer a little. Id rather have the ZZ4 over the LT1.
A lopey idle is not the sign of a hot car. It just means that the engine has a hard time running at low rpms and can't make power until it is in the +3500 rpm range.
Sorry
Sorry
new cam for 305
I agree that you should use the lt4 hot cam I have it in my car and it is amazing. It also has the lopey idle that you want. You will have to get 24lb injectors and a custom prom. The car will run with the stock chip but it will set some codes. I'm still running the stock chip my chip just came in. SO now I will be able to start tuning
will the lt4 hot cam work in a 305 TBI
before i put on the cast vortec heads i replaced the stock springs with a comp cams set that is good up to .575 lift
should i keep my 1.5 rollers or upgrade to 1.6
i think the lt4 hot cam gets .525 lift with a 1.6 rocker is that to much for a 305 and will it effect the stock ECM
IMHO .525 lift is a bit much on a TBI engine, no matter what heads you have. Since you have roller 1.5s already I would just stick with them. That still gets you almost .500" lift, but will help keep the vacuum and port velocity up.
so with a tbi setup can i still run the lt4 hot cam or will i run into problems with vacuum
would it also be better to upgrade to 1.6 rockers
with that much lift you are sure that it wont effect the stock computer
what about getting a new chip burned?
Just because some guys have hotcams in their 305 and think it's the best thing since sliced bread doesn't mean it's the best thing for you. I'd really like to see what other mods these guys have, and most importantly, what their 1/4 mile & dyno numbers are. A hotcam is WAY too much cam for a mild 305, and definately more than a stock TBI setup is going to function around.
First of all, are you running L31 vortec heads or the 305 equivalent? The L31s flow very well, but on a 305 you're going to have a lot of valve shrouding because of the cylinder bore being so close to the valve. I wonder if a high lift cam would help offset that problem, or if its effects would just be masked by the shrouding issue.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
oldschool
Feb 9, 2016 09:21 PM
DropTop91
22
Aug 8, 2002 10:53 AM
