Has anyone fixed the jet hot slip fit primary?
ssbowtie1
04-05-2008, 01:32 AM
What a lame design by Hooker/Jet Hot. After reading endless threads I tried using a 1 3/4" tbolt clamp and that did absolutely nothing. I've seen other posts recommending different kinds of sealants. Has anyone had any long term positive results with anything? The last option I can think of is to take the header off and notch the primary and try the tbolt clamp again.
Oh and anyone that doesn't think their slip fit is leaking, turn the car on and hold your fingers near the slip fit primary. You might be surprised.
ssbowtie1
04-10-2008, 11:29 PM
No one?
mdacton
04-10-2008, 11:31 PM
Mine has never leaked......
put some orange silicone on it
OutKast
04-11-2008, 10:16 AM
I haven't heard mine leak in 10 years but I can understand where it could leak when cold. The way I understand it is that the expansion from heat should seal it up good. I figure if it were leaking I would also see a bunch of carbon in the area.
Pontiac_97
04-11-2008, 11:17 AM
3" band clamp. no more leaky leaky :D just overlap the joint and it will contour to the pipe once you torque it down
MEAN LT1
04-11-2008, 11:32 AM
No leak in 7 years.:)
Kaj
04-11-2008, 12:54 PM
my96z
04-12-2008, 08:19 PM
No leaks here and I didnt even use a clamp.
red 95 z28 lt1
04-14-2008, 12:46 PM
mine leaks, tried rtv and a t band clamp but not over the actual leak
