ORY pipe for PS LTs ??
LJM97Z
04-02-2008, 05:38 PM
I'm getting ready to order my headers tomorrow, also looking to get the ORY pipe too, but it looks like the picture shows more of an exit in the middle of the pipe:(, will the ORY pipe work with my existing Cat back system, or will the main pipe on the ORY not be in line with my existing I pipe? If this makes sence. its the Magnaflow catback system with a 3" I pipe
2000GTP
04-02-2008, 06:50 PM
The i-pipe on my Magnaflow lined right up with the Pacesetter ORY. I clamped the two together with a band clamp.
LJM97Z
04-02-2008, 06:59 PM
Cool, looks like i'm in business then, i called PS, they said it should be a direct fit too, man i'll tell ya, those manifolds are a PITA to take off, i'm down to 1 bolt left on the pass manny, got the DR off along with the steering arm, looks like i'm getting close :), I can see why these LT1s respond so well to a header up-grade, talk about choked up :rolleyes:
2000GTP
04-02-2008, 08:29 PM
On the drivers side, you might want to remove the coolant temp sensor from the head so when you install the header, you don't snag and break the plastic connector.
LJM97Z
04-02-2008, 09:49 PM
I was looking at that, thamks.
