88irocz28
04-01-2008, 02:44 AM
Hey guys,
I've been trying to scan and tune my 1994 LT1 m6 car with a serial ALDL interface cable hooked up to my HP dv9000z laptop through a Belkin F5U103 USB-serial adapter but it just won't establish communications with the PCM. FWIW, the laptop is running vista premium. I know the cable is good since I've used it to tune other cars before.
I hooked up the interface cable to the ALDL just like it's supposed to go on there - red wire spliced into tan wire and black wire spliced into black wire. The trouble starts when I try to read my PCM or log any data. I installed both tunercat and Freescan in Windows XP sp2 compatibility mode as recommended on tunercat's website. When trying to read the PCM with tunercat, it returns an error message that the program can't establish a link with the PCM. I have tried all available COM ports 3, 5, & 8 in options without any luck. Device Manager shows the USB adapter set to COM port 8. I found an ALDL interface diagnostic utility on TTS powersystems' website that I used to troubleshoot my setup but the interface cable passed all phases of the test. The proper driver for the USB adapter is also installed.
Does anyone have any tips or tricks for making freescan and tunercat work through a USB adapter? I was told that I need to turn off my firewall and antivirus software, but the Norton crap my computer came loaded with won't let me disable it. I'm just looking for someone to point me in the right direction, any web resources, anything...
