Brake balance with C5's on the front '94 Z28 Vert
Future_Z_Owner
03-31-2008, 09:42 AM
Is there going to be an issue with braking balance if i put C5 calipers and rotors on the front of my '94 Z28 Convertible and leave the rears factory? I have C5's for all 4 wheels but i dont wanna lose my parking brake. So i would like to leave the rears factory if i could but if its going to be a problem ill deal with it.
always faster
03-31-2008, 11:27 AM
To balance the rear one on mine i ve put a wilwood proportion valve.
Future_Z_Owner
03-31-2008, 12:29 PM
:o I dont know what that does.. Can you explain please? Thanks :)
always faster
03-31-2008, 12:40 PM
Its an adjustable valve that you install on the rear brake line after the master cylindre.This way you can increase the pressure on the line and balance the rear brake.
Future_Z_Owner
03-31-2008, 12:46 PM
So it would actually make the front C5 brakes less effective?
shoebox
03-31-2008, 02:43 PM
Not if you don't adjust it that way. :shrug:
always faster
03-31-2008, 10:59 PM
Yeah thats why i ve put some c5 on mine :rolleyes:
Like shoebox said you need to correctly adjust it.You want the 4 wheels to lock practicly at the same time.
So you ask a friend to look at your braking on the side of the road.You bring it to 60 mph than slam(i mean it) the brake to make the wheel lock.This way your friend will tell you wich one lock first.
So you turn the valve nob clockwise(1/2 turn each time) untill the 4 wheel lock at the same time.
Thats it :cool:
NJ-LE
04-01-2008, 12:16 PM
This is the 1st time I've noticed mention of proportioning valve use on the C5 front brake upgrade for LT1 cars. Is this really necessary or is it just needed if the ABS is being deleted? What if a LS1 rear is also being installed?
maybe2fast
04-01-2008, 06:24 PM
I have C5 fronts...not alot of miles on the conversion (winter) felt awesome to me...
