wheel stud question
scott5
03-30-2008, 09:01 PM
I am sticking with my slicks and skinnys and decided to upgrade my studs in the back. What you guys recommend getting? Also coudl you tell me which lug nuts to go with them? I have stock axles and stock rear end.
Injuneer
03-31-2008, 08:45 AM
Without knowing the brand of the wheels, I don't see how anyone can answer your question. Do they use conical lugs or shank style lugs?
scott5
03-31-2008, 12:36 PM
oh, sorry i forgot to add that.. They are Weld Draglites 15x10 with 6.5 in back spacing
blue 79 Z/28
03-31-2008, 01:30 PM
direct replacement is arp #100-7708 wheel studs. those are the shorter of the 2 avail. 2.5" i believe. keeps the metric bolt pattern. ARP #100-7713 are 3.25" long they are both 12mm x 1.5
scott5
03-31-2008, 01:49 PM
thanks
Injuneer
03-31-2008, 01:55 PM
And you use the same Weld long shank lugs you already have, no matter how long the studs are.
With 3" studs on mine (1/2-20 screw-in), the ends of the studs stick about 3/8" out of the end of the lugs.
