question for installing vacuum canister for brakes
thebufenator
03-28-2008, 09:37 PM
Hi, I bought a summit can to help some with my brakes since my cam is kinda big.
The fittings are all smaller then the stock vacuum fittings.
My question:
Does the one way valve on the brake booster need to stay? Or can I just use the one on the can? THis will make it easier to get the correct fittings on :)
red 95 z28 lt1
04-01-2008, 02:19 PM
i dont remember what i did but i tried the vacuum canister and it dident work for me. i now use a vacuum pump and it works alot better its also smaller and wiring is simple
its from ssbc
mzgp5x
04-02-2008, 11:29 AM
Did the same. Mounted the SSBC vac pump in rear pan area since no up_front room due to D1 prcharger. Long line, (used 1/2" alum) but, works OK. Lost vac assist (3" Hg @ idle) due to FI positive intake manifold pressure. The other solution was to go hydraulic w/ use of the PS pump. More expensive, and, more install work. SSBC says you need 16" Hg minimum vac assist for satisfactory brake force. B.
