Sub-frame connector install ~missing bolt or not?
Joe Bellman
03-27-2008, 09:03 PM
I just received a set of BMR tubular sub-frame connectors from Thunder Racing and was reading through the install directions (see here: http://www.bmrfabrication.com/instructions/sfc001.htm )
It says "Using the provided hardware, slide bolts through subframe connector, subframe, and control arm and install nut finger tight.
I did not receive any hardware. Do I need a longer bolt to do this install and anybody what size? Thank you
Injuneer
03-28-2008, 09:56 AM
From the photos you linked, appears they reused some rusty old bolts.
lastZ
03-28-2008, 10:26 AM
BMR should have sent the correct length bolts with the sub frame connectors.....mine came with a pair/
Joe Bellman
03-28-2008, 11:36 AM
thanks guys.
