Starter doesn't always engage?
sloantbone
03-26-2008, 05:45 PM
Here is a question . I have a 95 firebird 3.4 motor.
Question is concerning the starter.
When I go to start the motor, the starter doesn't always engage....often you just hear it spinning like crazy. After a couple of tries it kicks in and starts the car.
Is there an easy solution to fix this problem or generally do i need to replace the starter?
I am pretty sure that that starter has all its gear teeth..meaning I have not been trying to crack it while the motor was running.
Thanks in advance
Gary
sloantbone
03-26-2008, 09:31 PM
Ok...think i researched this question using other posts on the same subject. I will try replacing the solenoid tomorrow.
Let you all know how it works out.
