GreasyB
03-24-2008, 12:08 AM
What loctite do you guys use on flywheels. Or do you use any.
Flywheel loctite, What color?GreasyB 03-24-2008, 12:08 AM What loctite do you guys use on flywheels. Or do you use any. mdacton 03-24-2008, 12:11 AM Flywheel to crank? I use nothing. Flexplate I use lockwashers, Locktight can melt around 300 degrees or so GreasyB 03-24-2008, 12:24 AM Alright. Well I will just put it in dry then. wrd1972 03-24-2008, 09:59 PM I have used red many times, never any sign of melting. I would definitely use it on the pressure plate bolts cause those dudes dont get torqued very tight. | ||
