torque converter will not lock
whitelightning93
03-23-2008, 05:54 PM
1993 a4 formula
torque converter will not lock at all fluid is good and it is all stock and throwing no codes
12SCNDZ
03-23-2008, 11:00 PM
Um...the most obvious is often overlooked. Check for a blown fuse. Have it scanned and see if the computer is commanding lock-up. Many parameters need to be met for the computer to send the command. Bad brake light switch? Bad connection at case connector? Bad lock-up solenoid? Stuck TCC valve? Bad converter clutch?
Frank
CPT
