dirtydsm
03-23-2008, 04:27 PM
It has a small issue when we park the car without the e brake it rolls back (its auto) what could this be?
:confused:
:confused:
1995 Camaro Z28 Autodirtydsm 03-23-2008, 04:27 PM It has a small issue when we park the car without the e brake it rolls back (its auto) what could this be? :confused: shoebox 03-23-2008, 06:09 PM Rolls back how much? All autos have a little slack when you put it in park. LSWHO 03-23-2008, 07:10 PM All autos do it less than 6" or so. dirtydsm 03-23-2008, 08:07 PM rolls back like a manual car without e brake its like in neutral. LSWHO 03-23-2008, 08:16 PM Check the linkage (on the tranny and in the center console). Then if that doesn't work fix the broken tranny. 12SCNDZ 03-23-2008, 10:51 PM Try to disconnect your linkage, at the transmission. Move the transmission lever to the park position. See if the car tries to roll then. If your linkage doesn't line up with your cable, you may have a cable/shifter issue. Has the transmission ever been built? The bolts that retain the park linkage, in the transmission, could have backed out. Frank CPT dirtydsm 03-24-2008, 06:30 AM Try to disconnect your linkage, at the transmission. Move the transmission lever to the park position. See if the car tries to roll then. If your linkage doesn't line up with your cable, you may have a cable/shifter issue. Has the transmission ever been built? The bolts that retain the park linkage, in the transmission, could have backed out. Frank CPT completly stock car will do that LSWHO 03-24-2008, 01:13 PM I had the same problem. Then my shifter stopped putting the car in drive correctly. Then I realized my shifter wasn't truly putting my car in park and that my linkage on the tranny somehow got loose. REAL loose. | ||
