z275plus
03-23-2008, 02:09 PM
What can I use to block off the Air tubes on my pacesetter mid tube headers ?
Air Tube Block Offsz275plus 03-23-2008, 02:09 PM What can I use to block off the Air tubes on my pacesetter mid tube headers ? Injuneer 03-23-2008, 11:37 PM On what year car/engine? 'Signature' ? ? ? ? ? ? ? ? ? danhr 03-23-2008, 11:51 PM get the tubes that originally went to your exhaust manifolds. get ahold of the flange that went directly to the exhaust manifold. cut the tube off. get your hands on a welder, and weld the hole shut. z275plus 03-24-2008, 06:30 PM Sorry about that, this is for a 95z, LT1. NJ-LE 03-25-2008, 08:28 AM z275plus: If they use the same size and pitch as my 95 then try this outfit. Some member in the forum (can't recall who) suggested ... http://www.cgenterprises.com/drain_plugs_metric.htm ... I got 3 plugs and gaskets mailed to my door for less than 1 blister-packed plug at the local auto parts. I used: #1016 22MM-1.5 Hex size=19 Thread length=12.5 #2508 22mm copper gasket toll free phone orders too: 1-(800)-565-9743 Injuneer 03-25-2008, 11:22 AM Those are OK for 99% of the 95's. The dual-cat "CA emissions" A4 cars have the smaller threads used on the 96/97 cars. Check before you buy. Me>you 03-25-2008, 12:26 PM You can make them yourself from sheetmetal, and gasket material...Done it 3 or so times for some lads down here Injuneer 03-25-2008, 06:39 PM How do plug a 3/4" deep female threaded hole with sheet metal? I can see how that would work for the EGR holes, but its difficult to picture it on the AIR connections. Kaj 03-26-2008, 01:07 AM How do plug a 3/4" deep female threaded hole with sheet metal? I can see how that would work for the EGR holes, but its difficult to picture it on the AIR connections. was wondering the same thing myself... danhr 03-26-2008, 01:11 AM was probably thinking of either the egr or the ls1 air fittings Me>you 03-26-2008, 01:31 AM Yes, i was talking about the far superior LS1 motor :p 2000GTP 03-26-2008, 06:02 AM Yes, i was talking about the far superior LS1 motor :p Nice response, and very helpful info you provided considering the original poster has a 95.:rolleyes: SNOTGREEN 03-28-2008, 09:48 AM R&D Speed, supporting vendor on here, sold me mine for under $20. Look nice too! :) Injuneer 03-28-2008, 05:07 PM R&D Speed, supporting vendor on here, sold me mine for under $20. Look nice too! :) Your 93 is different than all other years. The AIR for the passenger side manifold is integrated with the EGR system. That's not the case for 94-97, where AIR and EGR are two seperate ystems, and require different blanking plates for the EGR and plugs for the AIR, | ||
