Aeromotive AFPR
jchevy
03-19-2008, 08:51 PM
Should I see a difference in fuel pressure when I connect and disconnect the Vacume line to the regulator? Seems like I did when I first set it.
I noticed my car has been leaning out on the top end a little bit and I checked my fuel pressure. Its dropping to about 25psi when I get on the gas, with the car idling the fuel pressure doesnt rise like it should when I remove the vacume leak.
This is the boost sensitive regulator by the way. What a piece of crap, had nothing but problems with it.
When I first went to install it one of the brackets was bent 180* the wrong direction.
Then after driving the car for a month I was leaking fuel badly b/c the fittings all loosened up. They must have been just tight enough that i couldnt tell they were loose and it didnt leak when I first got it running.
Now this stupid problem.:mad:
roguedriver
03-19-2008, 09:48 PM
Is this on a stroker setup?
Ken R.
jchevy
03-19-2008, 09:57 PM
No, stock bottom end.
jchevy
03-19-2008, 10:01 PM
I took the FPR apart and put it back together, seems to be working better now.
What a peice.
Sparkz28ss
03-19-2008, 11:45 PM
I like the cheaper accel unit....works well... and it cheap
94SLUG
03-20-2008, 12:22 PM
I had that unit replaced it like 4 times went back to the stock uinit. Its been fine..
Sparkz28ss
03-20-2008, 03:46 PM
Accel or Aeromotive?
94SLUG
03-20-2008, 05:08 PM
Aeromotive FPR.... On side note every accel item I have purchased has also failed, sounds like their Opti is a pile too. IMO keep as much ac delco as you can! My accel coil failed at 4500 rpm and above...
1982z28with18s
03-21-2008, 06:30 AM
The cheapo borg warner one from Oriellys works great!
Kevin Blown 95 TA
03-21-2008, 11:11 AM
Sounds like you got the bracket for the Corvette instead of F-body. The fittings should always be checked on anything like that before you install it. You sure you have enough fuel pump?
jchevy
03-21-2008, 11:26 AM
At idle, yeah, Im sure a stock pump could handle it. So I should be seeing a fuel pressure change when i connect and disconnect the vacume line. I have that now that i tool it apart and put it back together.
On the top end, I think I have a fuel pump issue
