jchevy
03-18-2008, 10:08 AM
I need help deciding on a cam.
355, srp-24cc pistons, eagle h-beams, not sure what crank yet, probably stock. I plane to run 15 psi with an intercooled t-67, log headers. I would like to make peak HP 6200 rpm max or below.
What cam should I be looking at. Would the 224-236 114 LSA be a good choice, what about the 230-236?
Right now Im using a 224-236 on a 110 LSA from when the motor was NA, should I just continue to run this one after my rebuild? WIll I notice a difference going to a 114 LSA?
