blkgagt94
03-18-2008, 03:37 AM
i gota leak around where i put a new cat at where it meets the y pipe it leaks along the top an some on the bottom an a lil in the back. what can i use to seal this up?
leaks with new Exhaustblkgagt94 03-18-2008, 03:37 AM i gota leak around where i put a new cat at where it meets the y pipe it leaks along the top an some on the bottom an a lil in the back. what can i use to seal this up? mrmint69 03-18-2008, 04:29 AM I used aluminum foil and band clamps. I folded it enough times that it was thick enough to hold up. Kaj 03-19-2008, 04:43 AM you could have it welded.... blkgagt94 03-20-2008, 12:06 AM ya i can have it welded but if i need to get it off i cant unless i cut all the welds an dnt really wanna do that Kaj 03-20-2008, 12:21 AM What kind of system are we talking about here? IdahoLT1 03-23-2008, 05:48 AM i have an off road pipe that i swap out with the cat converter when emissions are due. The pipe and cat have flanges and bolt holes so i can swap it out fairly quickly. If you have this type of connection, you can buy gaskets for it or you can use a RTV high temp silicone sealant. | ||
