ohm reading
yourmom
03-17-2008, 06:12 PM
how do i found out the ohm of my type r's i bought them used and am not in contact with the man. any way i can check with ohm meter
NAVY01Z
03-17-2008, 06:33 PM
Just take your ohm meter and put it on the terminals on the back of the sub. Type Rs are dual coil. Measure each coil individually. If the sub is not blown the reading should be the same. Make sure you test without the sub hooked up so that your reading is right.
yourmom
03-17-2008, 10:07 PM
what setting of ohm reading do i set my multimeter to
THE_RUCKUS
03-20-2008, 10:01 AM
the lowest you can. the speaker is going to read either 2ohm or 4ohm per voice coil.
depending on which speaker you have, the whole speaker should read 1ohm, 2ohm, 4ohm, or 8ohm depending on the individual voice coil impedance and how it's wired. this is per speaker.
remember, most amps will NOT support a 1-ohm load.
