lots of f-body parts FS in dfw
here's a list of everything i can think of. if you need anything not listed feel free to shoot me a pm
complete running LT1 out of a 95 formula. 125k miles had been sitting for a few months and developed a miss fire at high rpm's (more than likely just needs a tune up). idles great, starts everytime first try. comes complete with all accessories, wireing, and pcm. $900 obo
A4 LT1 tranny 125 k miles stock works good-$200
LT1 A4 radiator-$80
LT1 dual fan assembly with pig tails-$80
LT1 A/c condinser-$25
tan seatbelts-$50 full set front and rears
93-95 firebird/trans am dash-$80
96-02 firebird/trans am dash-$80
firebird/trans am HVAC controls-$25
firebird headlight control panel-$15
110 MPH LT1 gauge cluster-$30
a4 pedal assembly with sensors-$40
rear view mirror-$10
hard top a-pillars-$20
tan dome light-$10
LT1 e-brake cables-$30 set
LT1 fuel sending unit-$40
formula rear bumper in red-$30
black firebird tail light center section-$20
LT1 k-member-$40
aluminum M6 driveshaft-$100
A4 steel driveshaft-$40
a4 steel V6 2 pc driveshaft-$30
2.73 V6 10 bolt rear complete with drum brakes-$80 picked up
stock torque arm-$20
complete set of gray cloth firebird seats-$100 picked up
93-02 passenger airbag-$30
95 and up gray firebird/ta drivers airbag-$40
93-96 camaro drivers airbag-$40
stock LT1 cam shaft-$30
drivers window motor-$20
LT1 water pump-$30
AC lines from the compressor-$25
dual horn assembly-$25
e-brake handel assembly-$20
96-97 airbag sensor-$20
96-97 LT1 timing chain cover-$60
LT1 accessory bracket-$40
stock 10 bolt diff cover-$10
stock LT1 valve covers-$20
stock LT1 exhaust manifolds-$25 picked up
96 stock descreened maf-$40
LT1 starter-$40
LT1 M6 complete pedal assembly with sensors-$60
M6 clutch line-$20
M6 clutch master cyl-$30
clutch fluid resivor with line-$10
t-top a-pillars-$25
Lt1 radiator shroud-$25
LT1 a4 flex plate/starter ring stock-$20
LT1 power steering pump-$25
LT1 brake booster-$20
LT1 brake master cyl with resivor-$20
trans am firebird tail light wireing harness-$20
LT1 2pc crank pulley-$25
LT1 under drive pulley-$20
t-top divider (on the roof)-$20
steering rack-$40
V6 k-member-$30
93-97 camaro headlight bar with lights-$80
93-97 firebird/ta headlight bar-$50
93-97 passenger headlight assembly with motor in white-$100
93-96 camaro dash-$80
tinted passenger t-top-$120
93-96 camaro headlight controls-$20
all prices are OBO and without shipping
i'm located in mansfield tx 76063
my paypal is f-bodyparts@hotmail.com
thanks
robbie
LT1 A4 radiator-$80
tan dome light-$10
LT1 k-member-$40
LT1 water pump-$30
LT1 starter-$40
M6 clutch line-$20
t-top a-pillars-$25
steering rack-$40
V6 k-member-$30
thanks
robbie
