Munson
03-09-2008, 11:19 PM
What are the settings on the stock bose sub in the rear hatch? I am curious as to its size, ohm rating, and wattage that its amp puts out. I am thinking about replacing mine with this.. http://www.sonicelectronix.com/item_11643_MB+Quart+RVF+164.html#
Tell me your thoughts. Thanks
Crows89RS
03-16-2008, 12:05 PM
the stock bose "sub" isn't even really a subwoofer... it's just a speaker like the fronts that is just made to filter out the high frequencies and only play low frequencies. i believe it is a 2 ohm speaker. don't know much more about it.
96 Z 28
03-16-2008, 10:59 PM
YUP as stated above, oh and yeah thin paper cone FTL.
Not worth the trouble to fiddle with, you either don't care enough or it's garbage:rolleyes: if you care it's better to just replace the entire system, or at least drive amps via a PAC OEM1 line converter & all new speakers + plus a real Sub:cool: I did that for a while, but eventually went to an after-market head unit:bow:
