Big Block Camaro
09camaroZ28
03-05-2008, 03:42 PM
i no this would never happend but i brought it up 2 see wut people think wouldnt you love to see a 454 big block in the new 5th gen camaro :D
FiefSS
03-05-2008, 04:08 PM
For a drag car, yeah. For anything else it would be pointless since it would never pass emissions or get anywhere need 30mpg on the highway.
So no I wouldn't want to see it. More interested in a Turbo 6.
bossco
03-05-2008, 04:16 PM
I dunno, the Z06 is a health 427 CID and it does pretty good on the mileage and emissions front. Whats another 27 cubic inches (not that I see it happening), Besides GM is nearly using big block engines as it is, another 12 cubic inches and your into "small" big block displacement territory.
09camaroZ28
03-05-2008, 04:18 PM
i would love to see it and buy one but i no it will never happend
jg95z28
03-05-2008, 04:24 PM
I dunno, the Z06 is a health 427 CID and it does pretty good on the mileage and emissions front. Whats another 27 cubic inches (not that I see it happening), Besides GM is nearly using big block engines as it is, another 12 cubic inches and your into "small" big block displacement territory.The LS7 is still a small block and it is soon being phased out.
Its been 35 years since you could order a big block Camaro. It won't happen.
5thGen
03-05-2008, 09:35 PM
I thought Big Blocks and small blocks were actually different block designs completely, the names being attached after the end results were seen. Considering the last vehicle with a big block at all was more than 10 yrs ago, I don't think they'll pull it back off the shelf and put it in a car.
However it would be cool if someone like Merlin or Dart made a big block based off the LS engines complete with fuel injection. 500 cubic inch LSX. It'd also be cool to see it in a limited edition series of Camaros and Vettes. Too bad Baldwin Motion went all out on that repop 69 vert with the overdone "styling".
ImportedRoomate
03-05-2008, 10:36 PM
The 8.1 in the trucks that was recently discontinued was considered a big block.
And yes, big blocks were just different blocks with larger outside dimensions. There was a 348 big block according to wikipedia.
90rocz
03-05-2008, 11:00 PM
And they weighed over 200lbs more.:eek:
Big "Inch" and Big "Block" are different.
Big Block = Bigger: bores, strokes, heads, balancers, valves/springs, ports, intakes, exhaust manifolds, thicker castings....etc....bigger all around.
I'm building up a 454 ci. BBC '72 Nova"SS" for a friend right now...it's huge and h e a v y...
But the new 427 is a bored/stroked out small"block" lighter, leaner and meaner.
mlars
03-06-2008, 12:15 AM
Not really. I just want to see the LS3 in the new V8 camaro!
guionM
03-06-2008, 03:34 AM
Dumb idea.
1. Big blocks are very heavy.
2. Small blocks put out phenominal horsepower nowadays.
3. GM created a 427 out of a small block.
4. Fuel economy of a big block downright blows.
The most powerful 454 (the LS6) put out 450 horsepower and 500 lbs/ft of torque by the optimistic, old, "gross" horsepower measurement. Yet stock LS3s are putting out 430 hp and 424 lbs/ft of torque by today's far more conservative "Net horsepower rating that was made more conservative a few years ago. In short, the current LS3 small block puts out power on par with the old LS6 big block.... while getting about double the fuel economy and next to no emissions.
And GM's not alone. The small block 6.1 Hemi from Chrysler matches the power output of the old big block Hemi in stock form... and outpowers the old Hemi if you use the same horsepower standard on both.
Big blocks make no sense anymore. There is no horsepower advantage, fuel economy is miserable, and they are barely more than large sized boat anchors.... not exactly what's needed hanging out on the nose of a Camaro (or any car). They don't even make sense in large trucks anymore.... diesels create more torque and still get superior fuel economy.
AdioSS
03-06-2008, 04:07 AM
Geez. Personally, I would love to see a new aluminum big block Camaro. A 502 using the same technology as an LS7 could make 600hp. Uh, oh yeah, there's that LS9... Well, how about the fact that you can get 572cid from that 502 block? That'd be ~675hp at the same efficiency as the LS7 with about the same weight as the blown LS9.
I know it'll never happen, but we can dream, right?
jg95z28
03-06-2008, 11:38 AM
I know it'll never happen, but we can dream, right?You can dream, but what you are suggesting is pure fantasy.
There's no way a 572 big block has the same efficiency as an LS7. No way, never, forget about it. The Street version of the ZZ572 puts out 620hp and 650lb-ft of torque. Yet the LS9 is rumored to put out about 620hp with a supercharger and only displaces 6.2L (378cid). Which is lighter and more efficient? Which will last longer on the road and be less of an impact to CAFE?
GM killed the idea of putting a big block in Camaros back in the early 1970's for a reason. Today they can build small block V8s that are more efficient and put out more horsepower. (Heck even their 4 cylinder engines have more hp than their V8s of 25 years ago.)
If you're going to suggest putting a big block in a modern Camaro, you may as well start suggesting we dump EFI for a Holley double pumper. :rolleyes:
wildpaws
03-06-2008, 02:51 PM
There certainly was a 348 big block, it was the smaller version of the 409 big block, came out in the early '60s.
Clyde
09camaroZ28
03-06-2008, 03:20 PM
Dumb idea.
like i said before i no it would never happen but since there was no new news out i just thought of throwing the idea out there also the small blocks back then were putting out little hp but now look at them maybe if big blocks were still here today they would be getting very high hp to
AJCUSTOMS
03-08-2008, 10:39 AM
I would love to have a big block in the new camaro, but in other cases i would take the LS9 thats in the ZR1.
AJCUSTOMS
03-08-2008, 10:41 AM
Dumb idea.
If big blocks are heavy then put some aluminum manifolds or something to make it lighter!!!
POWERFREAK
03-08-2008, 11:12 AM
Noooo.....big blocks are REALLY heavy. With all the CAFE/tree-hugger concerns, big blocks are a thing of the past.
bossco
03-08-2008, 11:20 AM
I know its a small block based on external dimensions, perhaps I should have added displacement wise, as of late, it seems engine builders have been able to swing some really big strokes to get some hefty increases in displacement.
The LSx engines, Fords Windor engines (up to 460 cubic inches last time I looked), and whatever Chrysler has been able to do.
It almost seems with the advances in airflow technology that having a "real" bigblock (unless your striving for some really big displacements) is almost pointless.
Z28x
03-08-2008, 12:16 PM
Engines like the S/C 6.2L have replaced Big Blocks
09camaroZ28
03-08-2008, 04:19 PM
would gm be able to make a 454 small block like they did with the ls7 427 small block
ehaase
03-08-2008, 04:59 PM
Clyde
1958
jerminator96
03-08-2008, 05:45 PM
Yes. In fact they can make a 500+ cubic inch small block.
A lot of you are comparing the old factory BBC with the Gen III small blocks, just not a fair comparison. Given the same level of technology there is no way a 454 small block can make the same kind of power as a 454 big block. You can only make so much power with 4.4" bore spacing.
The big limit in SBCs is and always has been cylinder head technology. If you can't feed the 427ci+ then there is no sense in having them. BBCs are not limited in cylinder head technology, take the new Dart "Big Chief" heads, if you want a 600ci motor you can feed it.
I'd love to see a BBC in the camaro, but the packaging is just too much. I would like to see GM abandon the old 4.4" bore spacing in favor of something a little bit more substantial though. Then we would see some decent head technology to feed some of these big cube beasts.:D
wildpaws
03-08-2008, 06:44 PM
Originally Posted by wildpaws
"There certainly was a 348 big block, it was the smaller version of the 409 big block, came out in the early '60s.
Clyde"
1958
OK, to be completely correct it was introduced in October of 1957.
Clyde
94studcar
03-08-2008, 07:21 PM
:( I didnt know this, I cant believe GM doesnt make a big block anymore, I loved the 8.1 in my parents dually, plenty of power, too bad it got 12 mpg on a good day! I was hoping GM woulda came back with the half ton SS with an 8.1
GMRL
03-08-2008, 07:32 PM
500+ inch tall deck LSX block for the stipped down drag version would be nice.
jerminator96
03-08-2008, 07:46 PM
GM is still short a crank with a 4.5" stroke and heads that wouldn't choke a motor that size.:)
GMRL
03-10-2008, 12:53 PM
That we know of so far, we all know how they have things up their sleeve.
AdioSS
03-10-2008, 03:13 PM
an even better idea would be to increase the bore centers to the same 4.5" as the R07 ;)
jerminator96
03-10-2008, 04:06 PM
Great minds think alike.:thumb:
bossco
03-10-2008, 09:38 PM
They could get all crazy with that 3 valve patent they got. I could see a cylinderhead flowing in the 4XX zone, plenty for a big inch smallblock street motor.
Rice Killer87
03-11-2008, 11:19 AM
Dumb idea.
That motor had solid lifter from the factory as well as a 850 cfm carb...It was rated that low solely b/c insurance companies were starting to crack down and they went by HP ratings on cars like that. My BBC that was on my 79 Z had HYDRAULIC lifters,LESS CAM, and the same size carb and had around 500HP easy to push that sled to 11.0X in the 1/4 everytime down the track.
LMAO. Find me a SBC car w/ a flat tappet cam,runs on 93,has FACTORY heads that runs 11 flat/7.0's in the 1/8 in a 3400 car. YOU WONT !!
And dont go find some LSX motor w/ some huge camshaft and milled heads call it stock.
jerminator96
03-11-2008, 12:39 PM
We're also not talking about drag motors in classic cars, we're talking about a production motor in 2010. I like BBCs as much as the next car but they just don't make sense anymore as far as weight and size are concerned. The new Camaro is already supposed to weigh what, 3800lbs?
By the way, if you want to go fast for cheap than SBC + supercharger or N2O will beat your BBC any day in the HP per $ competition.;)
GMRL
03-11-2008, 10:58 PM
I love BBs as much as anyone else on here, but you gotta be realistic too. Theres not much chance of a BB fitting under the hood of a modern production car, still weigh under 4000 lbs, etc.
I still think a big inch LSX would be the best choice, we all know that GM has the capability to do that.
mpilarZ281992
03-12-2008, 11:07 AM
Would not suggest a big block----very impractical and just absolute for the market. However, can you imagine that mean exhaust sound in that bad boy!!!!!!!!! Scary shXX.
09camaroZ28
03-12-2008, 03:44 PM
alrite if your gonna do that then we will put a supercharger or N20 on a BBC and lets see a small block beat that
GMRL
03-12-2008, 03:46 PM
As long as it fits in the engine bay.
jg95z28
03-12-2008, 05:23 PM
alrite if your gonna do that then we will put a supercharger or N20 on a BBC and lets see a small block beat that:rolleyes: What kind of fuel mileage does that BBC get? :rolleyes:
jerminator96
03-12-2008, 05:48 PM
Perhaps you missed the HP per $ part. Besides packaging concerns for a given power goal it's going to be cheaper to go with the SBC.
There is a range (somewhere between 500-700hp) that a BBC has the advantage. You don't need forced induction and factory parts with after market heads can make the power you need. Above and below that though, you can't beat an SBC.
