bilstein HDs with stock Z28 springs?
Old Mar 5, 2008 | 01:22 PM
redemn93's Avatar
i think the struts im looking at are from an lt1 car. i have a 98z28. would i screw up the ride of the car using that strut with my stock z spings?
Old Mar 9, 2008 | 08:03 PM
speedy-z's Avatar
Our cars have SHOCKS not STRUTS. You might get flamed if you continue to call them struts. But if the LT1 HD shocks you are purchasing are interchangeable with LS1 f-bodies, then yes, you can install them. Higher quality shocks = better ride. In our case, any replacement shocks = better than DeCarbon's. You aren't lowering so installing more expensive shocks will only make your car ride better.
Don't forget an alignment after it's all said and done.
Good luck!
F'n1996Z28SS
Aug 23, 2023 11:19 PM
CamaroHeed
Mar 18, 2020 09:50 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
