clean 4speed78z project w/ new forged motor
Old Mar 4, 2008 | 09:33 PM
11secgen's Avatar
this car is the simi famous(lol) 11secgen.texas car, no rust.
i have the motor all new in boxes.mahle forged pistons,6.0 eagle h-beams,scat forged crank,4 bolt block punched over for pistons,steel splayed caps(block not fitted for splayed)included,dart 2 sportsman 200cc heads,team g, holley 750, erson roller rockers.it will only need to be balaced before its ready to go because all parts are new.
car is in need of new carpet and front seat covers and will need paint.
i installed a truck arm rear suspension,but never got the coilovers or panhard rod for the rear, so it will need that but the fab work is done.has tubular subframe connectors with the truck arm crossmember neatly installed in between them, right behind the trans crossmember.
factory white,black interior 4speed z28. $2,500 for everything. pm me for pics or ill try to post some up if i can.no rust, ever.3k on the clock and not driven in over ten years, before that it was only used on weekends.2nd owner.this is my first car out of 30, to a good home only!near chicago, 60060 il.
Old Mar 5, 2008 | 06:23 PM
maverickmk's Avatar
can you send some pics to mavericksis@yahoo.com
Old Mar 6, 2008 | 03:20 AM
94GreenMachine's Avatar
what year is this car?
Old Mar 10, 2008 | 05:52 PM
11secgen's Avatar
its a 1978
also, has tubular upper control arms,and poly bushings.under hood area and sub frame were painted simigloss black and look perfect.also has solid body mounts and working factory cowl induction (not correct for this year, but every 2nd gen should have one!)
pics in the morning,ill try and post them here,as well as email them to anyone else who asks.
Old Mar 10, 2008 | 06:11 PM
camaro69z's Avatar
pics to zeppelinsg45@aim.com
Old Mar 15, 2008 | 07:56 PM
11secgen's Avatar
just installed the new balljoints and got it into roller mode,so that one of you can load her up.sorry pics in the mornin' and i mean it this time.sorry again for the delay guys.
Old Mar 17, 2008 | 06:21 PM
11secgen's Avatar
Old Mar 17, 2008 | 06:24 PM
11secgen's Avatar
Old Mar 21, 2008 | 03:07 PM
11secgen's Avatar
will trade for dirtbike.cr,yz,rm,sx motocross type bikes only.
to answer the question below: yes i will post some pics of the rear suspension as soon as i can.the lights in my garage took a dump,as you can tell, when i tried to take some pics but look for them this weekend.
Old Mar 21, 2008 | 03:09 PM
do you have or can you post some pics of the rear end suspension?
LeftoverChinese
Jan 14, 2024 03:03 PM
pimpss96
Feb 12, 2015 01:28 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
