tonka toy
02-27-2008, 08:50 PM
I want to put a cut off switch in my fuel system.I want to be able to crank the motor over (to build oil pressure) with out the motor starting.I was gonna splice a switch into the gray wire coming from the fuel pump relay to the pump,but I'm thinking it would be better to splice a switch into the ground wire going to the fuel pump relay.Would this be better or not? Thanks!!
