Major fuel problem need help?
DustinMcGowan
02-25-2008, 06:40 PM
I have a 94 z-28 with the LT1 and I am having a lot of trouble with it. The car seems like it is fluding due the the bad gas smell, but the car will not run. It wonts to start but dont. Then I pull the two fuses to the injectors and the car will start and run for a min. untill the fuel in the system is gone. Then I put the fueses back in and the same things wont run. Need help please. Thanks.
Dustin
11secgen
02-25-2008, 06:58 PM
check the fuel pressure.sounds like a classic case of the fuel pressure regulator blues.
Injuneer
02-26-2008, 12:38 PM
Please post a problem only in ONE forum. You already have this in LT1/LT4 Engine Tech.
