can you remove ZR1 center caps w/o taking the wheel off?
havent ever tried doing this but im getting new center caps for my black ZR1's and am wondering if i can pry off the old ones w/o taking off the wheels, or do you have to pop them off the back?
I did it and it was pretty easy with the right technique. Having a small pick tool and getting it just right will work the best. A razor blade will also work. Just be careful either way not to put nicks in the rims.
ok i replaced my center caps and did it the long way, ie taking off the wheels. but i have another question. i put the new caps on with the wheels on. they all seemed to go on ok although one of the rear wheels looks like the cap on one side is slightly further in than the rest of the cap. it seemes like its tight though and the rest are about as far out as the majority of that cap. only one small section is sunk in. my question is, do you need to have the wheels off to install center caps on ZR1's? they seem like they went on tight and i drove it around for a mile or 2 but not over 25mph. i just want to make sure i'm not gonna lose one down the road later.
squarehead
Nov 21, 2014 08:02 PM
Darth Xed
Jul 1, 2002 03:22 PM
