z28luva
02-22-2008, 05:28 PM
i just got a new 402 put in and the engine is smoking, running rough and every now and then misfiring. it doesnt always smoke however. i have 2 theories and was wondering if either one was correct.
1-my valves are out of whack and the engine is burning oil. i assumed this to be the case because of how rough the engine is running. but the smoke is white, which means that its most likely coolant being burnt correct?
2-the coolant is being burnt, which would explain the color of the smoke. and most likely i need a new head gasket. but would this make the engine run so rough? also my last engine (396) threw a rod out. when i drained the the oil tank there was a lot of coolant in there, so most likely this is the problem, atleast thats what i think. but once agian could coolant getting in the cylinders cause the engine to run rough and misfire like it is?
i also considered the timing being off, but the two above theories are what i am leaning towards. any help is appreciated.
edit-i would also like to point out that a lot of the smoking of the exhaust occured today. i didnt start the car yesterday and it rained for two days straight, could that have something to do with the white smoke?
