BlazinREDZ28
02-17-2008, 11:14 AM
Hi all, I'm close to pulling out my hair and taking a chainsaw to the car.....
First, I should say, we have fixed some assorted issues recently, new TB 52mm (had a vac leak there, linkage worn out), a wiring repair going to the o2 sensor (the engine bay side of this), and REALLY was hoping this would solve most of the trouble. Nope, of course not.....Sorry, this will be long.....
The car runs rich, rich rich, no raw gas pouring out of the tailpipes, but not good either. I have a couple of logs from Datamaster from last night, and I believe the right o2 needs to be replaced, it never really functions out of the 300 to 450mv 'ish range in closed loop. We get a DTC 33, can't get rid of it so far. There numbers from Datamaster are: BAR 102.6, MAP 73.5kpa at 875 RPM, Fuel trim 16. AFGS 14.07, TPS volts .69, IAC 81. The PCS is making fuel corrections all over the place.... Once into closed loop for a couple of minutes, I gave it a little gas, went into fuel trim 18, 1750 RPM....Right bank LT 119, short term 116, Left bank LT 122, short term 116. At this time in the log, BPW 2.11 left, 2.03 right. Inj DC 3.1 left, 3.0 right. TPS volts rose to .80. Spark advance 41.0, no spark retard, TPS% 3.1. MAP Kpa 51.3. If anyone can tell me how I can get this uploaded somewhere so it can be looked at. I can never drive the car hooked up to Datamaster cause the laptop battery will not charge. I am concerned about the high MAP, and the code, and why is it so rich. Maybe the AFGs are off as well? The MAF is descreened and was ported, from my understanding by previous owner. Is this causing some/ all of the trouble? As far as MAP, is the cam (Comp Cam 290/307 .510 intake, .540 exhaust, 112 lobe sep) causing this to be a high pressure/low vaccum situation? The PCM seems (correct me if I am wrong) to be thinking the engine is under a load at idle and a little above, and is dumping fuel at it. Again, correct me if I am wrong, cause chasing this one is making me nuts!!!! Will be checking the wiring for MAP today, MAF wiring is ok. BTW, The car has a new 255 Racetronix setup, new 42 lb lucas injectors, new TB, MSD 6AL, new MSD wires, and a new tune. I can't drive my car, and my pocketbook is getting lighter.......
