good fuel system for le2 setup
sn8ke eatr
02-03-2008, 11:18 PM
im looking to do a 355 le2 motor with about 12:1 compression. my question is what would be an adequate fuel system without blowing my budget. my car has 181 thousand miles and i know it would be wise to upgrade everything. so what would you suggest?. btw im running 32lb injectors already.
z28_theantirice
02-04-2008, 08:48 PM
Racetronix fuel pump kit and make sure your FPR is in good working order and you should be set!
sn8ke eatr
02-04-2008, 11:51 PM
cool thats what i was thinking, thanks
ulakovic22
02-05-2008, 06:00 PM
Might want to check out your duty cycle with those injectors once you get everything all together and ironed out. Might be a tad small and depending how close it is you might want to check out larger injectors.
