2nd 2 noss
02-02-2008, 02:27 AM
I have a 96 z28 a4.. my tranny line is leaking very bad. here is the deal I need to see if it is loose or is it bad.. do i have to drop tranny to tighten top line? is there another way? where can i get a new one?
tranny lines2nd 2 noss 02-02-2008, 02:27 AM I have a 96 z28 a4.. my tranny line is leaking very bad. here is the deal I need to see if it is loose or is it bad.. do i have to drop tranny to tighten top line? is there another way? where can i get a new one? Ricardo 02-02-2008, 05:39 AM You dont have to drop the tranny. It is a bit tight in there, but you can work your way up there and slip your hand in with a stubby box end wrench or a flare nut wrench. It helps a bit to drop the tailshaft. If the nut is just loose it should be an easy fix. You need to get your car up on a lift or at least generous space underneath to get this done. | ||
