Mother****in Hydrolocked My Motor:
Old Feb 1, 2008 | 02:43 AM
Kraest's Avatar
Retired
God this sucks... it's 2:30am and I'm just wrapping it up. Something internal is broken... I'm ruling out a bent rod or anything like that because it's a very rapid light ticking coming from the front of the motor like a valvetrain part or possibly something to do with the timing chain.
Anyway....
There was flash flooding today and I was going down a back country road to my house after work. Lo and behold I come upon standing water and don't think anything of it..... it's only about 6 inches deep and there's a bunch of cars crossing. I take the Z pretty slow across ... probably around 5-8mph at the most to keep it moving so that I don't get stuck... All of a sudden click BOOM and the car dies... I try to restart it and the starter grinds its *** off. Great. Broken starter due to a hydrolocked motor.
I finally get it home after pushing it out of calf-high water and getting my cousin to tow me back a mile or so to my house and start diagnosing it:
I pulled all of the plugs and turned over the motor to get the water out. I then pulled off the TB and looked inside and saw a small pond of water resting on my valley cover :eek I jacked the car up in the back and poured the water out of it, then my Dad had a good idea to stick a towel in as a "wick" and draw the rest of the water out. After a run to the store and many curses/bruises, I removed/installed the new plugs and kept my fingers crossed. I hit the starter and CRRRRRRRRRKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKK!!!!!!!!! ! No start I pushed the car down the driveway and popped the clutch to get it to start, but then heard the dreaded light tapping. The car runs perfectly, so I seriously don't think that it's a rod or spun bearing or anything like that, however, I'm going to have to pull the valve covers tomorrow or Saturday to see if I broke any valvetrain parts....
...Anyway.... 6:30am comes early and I have work....
Old Feb 1, 2008 | 04:31 AM
Kaj's Avatar
Kaj
damn that sux the big one bro. I Wish you luck man.
Old Feb 1, 2008 | 06:11 AM
soul strife's Avatar
I guess it was time for a rebuild anyway...? Sorry to hear that. Did you have an SSRA on it. I have heard they can scoop water. I think it helped hydrolock my buddies Z. I still have mine on though.
Old Feb 1, 2008 | 06:57 AM
Kraest's Avatar
Retired
Nah... the motor has around 30,000 miles on it... sucks.... like I said... it sounds like nothing too major... I expect it to be something valvetrain related.
Old Feb 1, 2008 | 11:37 AM
Marc 85Z28's Avatar
That REALLY sucks! Like soul strife asked: Did you have some sort of aftermarket "ram air" or cold air kit?
I've seen several different engines (not all necessarily LSx) with slightly bent rods still run decently with only a little bit of a rough idle. Hopefully that's not the case and you just damaged the starter - not the block mount on the outboard starter bolt.
Old Feb 1, 2008 | 12:31 PM
Kraest's Avatar
Retired
All I have is a lid. It shouldn't be a big deal. It's pretty unlucky to say the least.
Old Feb 1, 2008 | 12:37 PM
mdacton's Avatar
so is it a tap or what? Like a pushrod noise?
Good luck with it, Should have drove that F-150.........FORD tuff
Old Feb 1, 2008 | 01:03 PM
Marc 85Z28's Avatar
Your right - you can't hydrolock a late model Ford truck. If you get water in the cylinders they'll just spit the plugs right out of the cylinder heads to save the rods
Old Feb 1, 2008 | 01:13 PM
mdacton's Avatar
Don't talk bad about the #1 truck in the world, I get offended.
Kraest pull it down tonight, I want to know what the deal is. Pull an all nighter
Old Feb 1, 2008 | 02:26 PM
Rice Killer87's Avatar
That sucks man,hopefully its nothing major like a bent pushrod.
Old Feb 1, 2008 | 03:35 PM
Kraest's Avatar
Retired
A bent pushrod? I can only hope
I pulled the valvecovers and everything off. No broken rockers, no broken pushrods (they are 1 piece hardened), and no broken springs.
It's either a collapsed lifter or something worse.
It's going to Futral next week. I'm not about to pull the heads and stuff on it and find out that it's the bottom end
Mike
Old Feb 1, 2008 | 04:04 PM
Need4Camaro's Avatar
Sorry to hear man... Keep us informed as to what broke... I'll keep this as a Reminder that F-Bodies + Water = nono
Old Feb 1, 2008 | 09:27 PM
BadgeZ28's Avatar
How long did you let the motor run after you got it restarted? You can get a clacking sound from the AC compressor. The noise might go away if you let it idle up to temp? Good Luck
Old Feb 1, 2008 | 10:09 PM
V6toZ28's Avatar
Fra ...?
Old Feb 2, 2008 | 08:48 AM
Kraest's Avatar
Retired
Not really long. I need to change the oil before I attempt restarting it.
