Shift Problems Help???
DEEZ-Z28
01-30-2008, 11:33 AM
I own a 95 Z28 Lt1 with Automatic trans. Heres the problem. My shifter when put into park stays in reverse. Actually here is how the shift lays out
P = Reverse (no back up lights and car can be shut off and restarted in gear)
R = Reverse with backup lights car will not shut off and restart.
N = Neutral when shifting out of Reverse Stays in Drive when shifting out of drive.
OD = Drive with overdrive but shift mechanism doesnt prevent shifting into neutral. Shifter isnt locking in OD it can be moved to neautral position and stays in OD
D = 3 rd gear (will dowshift to 3rd but doesnt lock.)
2 = 2nd gear ( will shift into 2nd gear but doesnt lock)
Is this a shift cable problem or something else. Any help will be appriciated.
shoebox
01-30-2008, 01:19 PM
Check the shift cable at the transmission (especially, to see if the bracket has come loose). Or it may need adjustment (http://shbox.com/trans/A4_trans_linkage.html).
DEEZ-Z28
01-30-2008, 05:45 PM
Loose bolt on the cable bracket!!! Works fine now except for that intermittent work/not work of the Park Shift selenoid. Any ideas on this Shoebox?
