always faster
01-30-2008, 11:19 AM
Ok i got my ls2 coils with my ltcc box and harness with the ls2 connectors.
I dont know where i will mount the box but thats an easy job.Thanks to a nice member who answer in a previous post what connector was needed for my taylor wire.(part #46059 from taylor)
So now can we just make a complete post on the wiring and where to plug what?Im having just a little trouble finding where to connect everything.Or maybe i maybe just need some confirmation that all that i got is right...
I ve done some search and found some info but would need to be confirm.
So the wiring harness got:
-8 blue(ls2=blue/ ls1=black) coils connector= Easy one goes to each coils;
-8 black wire with a loop connector=These are ground;
-Big black connector connected to a bigger grey connector(looks like opti connector)=Those connect between the opti connector on the pass side of the intake;
Yellow wire:for nitrous only for retard;
white:is ground but need to be connect to a pcm ground @ ignition module(yellow with black stripes)@ ignition module;
2 pinks wire:connect them together then connect to the pink with black stripes(12volts).
So ami i right,wrong or maybe i missed some details or seomthing just need to be modify to be clear?
