94TeALFiReBiRd
12-12-2002, 12:57 PM
give me as much stock info as possible.... 1/4 0-60 etc..... engine things compression stock cam everything possible about the 3.4
3.4 info?94TeALFiReBiRd 12-12-2002, 12:57 PM give me as much stock info as possible.... 1/4 0-60 etc..... engine things compression stock cam everything possible about the 3.4 ibanez6rg 12-12-2002, 03:18 PM drivetrain/front engine, rear-wheel drive engine code/L32 compression ratio/9.0:1 displacement(liters,c.i.d.)/3.4L, 207 hp-rpm/160 @ 4600 torque-rpm/200 @ 3600 fuel induction/SFI (sequential fuel injection) fuel injectors/24lb Tiago 12-12-2002, 06:32 PM the injecctors are 17lb! ;) Ve/\/om 12-12-2002, 08:53 PM The 3.4 DOHC is better!!! I know...mid 15's vs. high 17's :p ibanez6rg 12-12-2002, 09:13 PM Originally posted by Tiago the injecctors are 17lb! ;) You sure?? :) V6 Punk 93 12-12-2002, 09:26 PM Originally posted by Ve/\/om The 3.4 DOHC is better!!! I know...mid 15's vs. high 17's :p High 17's? Maybe a few poorly tuned 3.4's are running high 17's but most of them I see are running mid-high 16's. 94GrayV6 12-12-2002, 10:43 PM This should help... http://engine.firebirdv6.com/ Oh yeah typical stock acceleration times are 0-60 in 9ish and 1/4 in the high 16s. Ve/\/om 12-13-2002, 01:47 PM Originally posted by 94GrayV6 This should help... http://engine.firebirdv6.com/ Oh yeah typical stock acceleration times are 0-60 in 9ish and 1/4 in the high 16s. http://wp.netscape.com/fishcam/fishcam.html MustangEater82 12-13-2002, 02:22 PM Originally posted by Ve/\/om The 3.4 DOHC is better!!! I know...mid 15's vs. high 17's :p the dohc 3.4L is very unreliable, likes to eat alternators, break timing chains, and a huge long list.... Very expensive to maintain. THe 3.4L has cast aluminum pistons.... which is a downfall when it comes to severely tuning it. 3.4L are typically high 16s.. and hey my 3.4L is mid 15s:) 94TeALFiReBiRd 12-13-2002, 02:31 PM yea i know someone with a 3.4 lumina z34 always messes up....... All_InTheRED 12-13-2002, 02:59 PM Originally posted by V6 Punk 93 High 17's? Maybe a few poorly tuned 3.4's are running high 17's but most of them I see are running mid-high 16's. And some very well maintained ones that run 17.8. .......and I have seen others do the same at the same track. fbird95 12-13-2002, 08:03 PM the dohc 3.4 Certainly does go along with the general scheme of grand am engines being unreliable. 94TeALFiReBiRd 12-14-2002, 01:10 AM Originally posted by fbird95 the dohc 3.4 Certainly does go along with the general scheme of grand am engines being unreliable. yea so true they suck!!!! Ve/\/om 12-16-2002, 12:14 PM Originally posted by MustangEater82 the dohc 3.4L is very unreliable, likes to eat alternators, break timing chains, and a huge long list.... Very expensive to maintain. THe 3.4L has cast aluminum pistons.... which is a downfall when it comes to severely tuning it. 3.4L are typically high 16s.. and hey my 3.4L is mid 15s:) Unreliable? Not really if well maintained....and there timing belt engines. ALL dohc 3.4's are forged aluminum rods/pistons. | ||
