Middle Atlantic New Jersey, New York, and Pennsylvania
LS1 F-body Procharger setup in NJ $2500
Old Jan 23, 2008 | 05:38 PM
Jeff H's Avatar
I don't want to ship it so I figured I would try the NE area first. If the thread needs to be moved to the for sale section just let me know.
I was hoping to put this on my car but once again I could really use the cash for the 69 Z28. I have an LS1 P1SC Procharger twin intercooler setup that is 85-90% complete. I have the P1SC head unit which has approx 50 miles on it, the 3.5" twin intercooler setup which includes the intercoolers, all the piping and hoses, the polished intake plenum(bling!), which includes the correct screw in IAT and the Procharger surge valve. I have a SPAL slimline fan, the supercharger bracket, 2 standoffs(1 needs to be trimmed down a little), the AIR/cruise relocation bracket, 6 rib crank pulley, 3 supercharger pullies(3.4, 3.5 and 3.7"), a set of SVO 42 lb injectors(approx 1000 miles on them). The setup still needs a new slightly longer crank bolt, the ATI fan shroud(which you can get from EPP), the ATI radiator shroud(also from EPP), horn relocation bracket(should be easy to fab up), the supercharger inlet hat, tube and air filter. I have an inlet hat that will probably work but it's not the ATI inlet hat. There are also some miscellaneous nuts, bolts and clamps needed but they are all listed in the installation book(which I have) so they won't be too tough to find. I'll try to get some pictures of the parts this weekend. $2500 and I don't plan to separate but might split up the injectors if someone wants them.
LETZRIDE
Outside of United States
Jul 9, 2015 07:17 AM
SmokinZ28lt1
Feb 5, 2015 04:33 AM
D1SC383LT4
Jan 26, 2015 01:41 PM
ddr698
Jan 9, 2015 10:05 AM
