bighash007
01-21-2008, 10:11 PM
Im having problems with my car battery. I changed out the alternator and battery. When in idle for minute battery gauge hits in red until i punch gas on pedal. Im wondering how is the charging systems (or batt. gauges) look at idle, and what the idle rpm is
SupplySgt.
01-22-2008, 12:07 AM
you should idle around 800-900 RPM. the battery should stay above the halfway mark at idle unless it's low. And you shouldn't have to punch the gas to get it to go to that point.
mrmint69
01-22-2008, 12:59 AM
Could be real simple like corroded connections or even loose ones.
bighash007
01-22-2008, 01:33 AM
like wires connected to the alternator or battery? could it be any other reason? like a short or ground?
bighash007
01-22-2008, 01:34 AM
at idle my battery goes below half it gets to beginiing of red
mrmint69
01-22-2008, 11:33 PM
I had battery connections that looked clean but there was a film that looked dull that keep it from making a good connection. I would go over everything you can check.
