Evolution223 01-15-2008, 08:45 AM Have you all ever checked these out??
Do they work?? Are they worth it? It sounds like an awesome idea.
http://cgi.ebay.com/ebaymotors/Electric-Supercharger-All-Makes-All-Models-HP-Turbo_W0QQitemZ230210791861QQihZ013QQcategoryZ3374 1QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
IXLR894Z28 01-15-2008, 09:52 AM Ummmmmmmm, NO!
Evolution223 01-15-2008, 10:24 AM what if you put 2 of them on a V6? I think it will give me about 15 hp up to 4500 rpm's.
Evolution223 01-15-2008, 10:36 AM at least I can run arround and say I've got a camaro with 2 superchargers...:p:p
Gripenfelter 01-15-2008, 11:08 AM I put 2 of them on my Camaro and kicked myself for spending all that money building a 383.
teke184 01-15-2008, 11:38 AM god .....not this joke again....
JakeRobb 01-15-2008, 12:06 PM The eBay listing you provided doesn't specify CFM. You could use that to figure out how much it would actually help you / hurt you. As long as the supercharger's maximum CFM is greater than the CFM currently being demanded by the engine, the supercharger will increase manifold pressure and therefore increase horsepower.
In the case of a centrifugal supercharger like the one shown, this involves spinning a turbine wheel at 40-50,000 rpm (basing those numbers on specs I found on the Procharger website).
I haven't actually looked to see what kind of 12VDC motor you can get for $70, but I am very doubtful that you could get one that could attain that kind of RPM (even with a gear reduction) and still have enough torque to build some pressure. Besides, some of that $70 goes to the pipe and the K&N filter, not to mention a profit for the manufacturer and the seller.
They say you could build 2-3psi of boost on some engines. I suspect they're talking about a very small engine, and I suspect they're talking about low RPM. I imagine it could give a 1.5L engine a little bit of extra low end torque, but I'm skeptical even about that. It's definitely not going to do anything for a big V8. :)
Evolution223 01-15-2008, 12:11 PM The eBay listing you provided doesn't specify CFM. You could use that to figure out how much it would actually help you / hurt you. As long as the supercharger's maximum CFM is greater than the CFM currently being demanded by the engine, the supercharger will increase manifold pressure and therefore increase horsepower.
yep, i did the CFM math and 2 of these would give me a boost up to 4000 rpm's if they do what they say. If not it will atleaset be good for laughs running around telling everyone I have a camaro with twin superchargers.:D I going to try this, if they don't blow pretty good out of the box I'll send them back but this should be better than a regular intake.
BTW - i actually found this one on ebay, it's a little better deal and more descriptive.
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&ih=006&sspagename=STRK%3AMEWN%3AIT&viewitem=&item=160197821691&rd=1
JakeRobb 01-15-2008, 01:22 PM yep, i did the CFM math and 2 of these would give me a boost up to 4000 rpm's if they do what they say.
I doubt that you'll actually see any real boost. Electric motors make maximum torque at zero RPM, and they taper to zero torque at maximum RPM. To run at max CFM, you're running at zero torque. With no torque, you're not going to generate any pressure. This means that you'll most likely be running at just a hair over zero psi. I really doubt that you'll see any noticeable difference at all.
Having said that, more power to you for trying it. When you install it, you should install a switch so that you can turn them on and off. Then get on a dyno and give us before and after charts.
Evolution223 01-15-2008, 01:51 PM I doubt that you'll actually see any real boost. Electric motors make maximum torque at zero RPM, and they taper to zero torque at maximum RPM. To run at max CFM, you're running at zero torque. With no torque, you're not going to generate any pressure. This means that you'll most likely be running at just a hair over zero psi. I really doubt that you'll see any noticeable difference at all.
yes but it will only run at max speed/cfm when your approaching 4000 rpm, all below that there will be a pressure boost, the most when the car is starting which is when you need it anyway so I look forward to feeling a difference with this or atleast bragging that I have a camaro with twin superchargers.:D I will post when I get it all done. The Kit does come with on/off swictes I think but if not I will install one in the dash.
00ls100 01-15-2008, 02:06 PM :confused:
:no:
bombebomb 01-15-2008, 02:11 PM I put one of these on my car, made me run 10's.
Evolution223 01-15-2008, 03:28 PM you are laughing but I bet this is the best HP for the dollar mod there is for a V6.
rcantrellz28 01-15-2008, 05:50 PM :shrug:2-3 psi?:rolleyes: if you do go out and get this defin.. post results. However I think it is a waste of $. Hell prove us wrong, please I would love to see some thing like that actually work but..........my bets on -waste - of - money;)
solarofthesix 01-15-2008, 06:04 PM YAY for selling RV Bathroom Blower Motors on Ebay!
mdacton 01-15-2008, 06:15 PM I put one of these on my car, made me run 10's.
me too.....with a v-6, I put 8 of them on mine
BC2002SS 01-15-2008, 07:50 PM how do they keep falling for this crap. just get a leaf blower at home depot and save shipping.
wdtiger 01-15-2008, 08:25 PM This is a joke, right? Please tell me that you're not actually talking yourself into thinking this works. Save your money and just get an intake. You'll see better results from that.
Kraest 01-16-2008, 10:51 AM Why are questions about a Y87 car posted in the LS1 section?
Why are questions regarding an electric supercharger posted at all??
Moving to V6 Forum.
Rice Killer87 01-16-2008, 11:41 AM Why are questions regarding an electric supercharger posted at all??
LMAO.
Anyone that even THINKS for a second that those work need a different hobby....like uhh....oh wait,youve gotta V6 anyway.
Evolution223 01-16-2008, 11:44 AM LMAO.
atleast I'm not the one stupid enough to drive a 1986 car that gets 12 MPG car when gas is $3.15 a gallon, now that's stupid. or puttin all your money in a race car and driving around in an extreme like a broke-ass isn't any smarter.
Evolution223 01-16-2008, 12:44 PM Why are questions about a Y87 car posted in the LS1 section?
Moving to V6 Forum.
because you dickhead no one pays attention to the v6 board so i put it in LS1.
Evolution223 01-16-2008, 12:51 PM I put 2 of them on my Camaro and kicked myself for spending all that money building a 383.
I'm not a idiot like you who goes into debt to build an engine that gets 12 mpg in a 15 year old car and now you've got to go into more debt because gas for it is $3.15 a gallon, now that's stupid.
JasonD 01-16-2008, 02:37 PM because you dickhead no one pays attention to the v6 board so i put it in LS1.
No one pays attention to forum when people don't post in it when they should. Cross-posting is not the answer.
Clean up your act here or post on another site entirely. This isn't the site for people who don't have the class to be respectful.
