ledfut1
01-14-2008, 05:37 PM
I was checking out a Z-28 on e-bay. He mentioned changing opti-spark in a `95 LT-1 with ignition from a newer LS-1 system. How big of a job is this.. My `95 is tore down now and would be a good time to change if not too technical of a job..Anyone have any info. on this changeover? thanks :)
Injuneer
01-14-2008, 06:18 PM
Perhaps he's referring to the LTCC setup from Bailey Engineering:
http://www.bailey-eng.com/LTCC.html
The only LS1 coil conversions I have seen, like the LTCC or my own MoTeC setup still use the Opti optical signal as the cam position sensor. The stock LT1 PCM needs the optical signals from the Opti to time the fuel and spark. It will not function without at least the low resolution pulse pattern from the Opti.
IROCThisZ28ForLife
01-14-2008, 08:43 PM
go to search and type in delteq or ltcc as Injuneer pointed out, plenty of info there boss
