reamo04
01-03-2008, 12:06 AM
135-INJ-L79FM-8 Racetronix Flow-Matched 79# Style Fuel Injectors (Set of 8)
-Static Flow Rate: 76.65 lb/hr = 9.67 g/s = 846 cc/min (+/-4%)
-Coil Resistance: 12.2 Ohms (+/-0.35 Ohms) (This high-impedance injector will work with all factory ECM/PCM injector drivers)
-Dynamic Flow @ 2.5ms PW @ 100Hz: 16.88 mg/pulse +/-10% @ 2.5ms PW @ 100Hz
-Gain: 0.11ms/mg, Offset: 0.055ms, Turn on time: 1.14ms @ 14VDC, Turn off time: 0.85ms @ 600KPa
-Dynamically flowed and grouped to within 1% tolerance using Racetronix custom injector flow bench
JW if anybody is using them.
Building a MP T70 turbo setup and am wondering if i should go with 60# siemens injectors, or the 79# racetronix for safe measures
