Anyone had a problem w/k-member/a-arms?
mdacton
01-01-2008, 10:59 PM
The a-arm sliding in the slots on the k member?
Whats the fix for this?
OBE1 95Z28
01-02-2008, 09:27 PM
Mine slid on me (BMR K member and lower control arm). Alignment shop used red loctite and cured the issue.
mdacton
01-02-2008, 09:32 PM
it was not an issue of the bolt being loose though.......it was even tight when I had to move it back.
They are sending star washers with the K-members now to grab into the tab....
This is a drag car and it did this when the tires came up then came down again......I'm not taking any chances...I have everything here so I got it all right as far as alignment and I will weld the washers to the tab....If I need to do anything I will just have to grind the weld......But its a sickening feeling having something in question when your going fast.....
I hate to take any chances
