Just bought exhaust
Old Dec 28, 2007 | 12:59 AM
naturally aspirated's Avatar
Just bought exhaust
I just bought a magnaflow catback from this guy
http://ls1tech.com/forums/showthread.php?t=831378
and I'm interested to know what all is involved in installing it?
I did my thermostat myself and replaced my own alternator and power steering pump, how difficult is it to do a catback?
Old Dec 28, 2007 | 02:29 AM
Kaj's Avatar
Kaj
I suggest an impact wrench with a chizle type fitting to remove your stock exhaust just before the pipe going over your axle. That's the easist way to remove your exhaust, and then everything in your kit from the magnaflow exhaust i.e. hangers/clamps is pretty straight forward, however after installing it yourself, take it in an get it welded at all connections just so you don't have any leaks.
You might as well look into getting a magnaflow or similar hi-flo cat to improve your flow and get the best possible flow out of your new found exhaust. good luck with your endeavors.
-Ky
F'n1996Z28SS
Aug 23, 2023 11:19 PM
95chwagon
Feb 28, 2015 12:02 PM
Chris Anderson
Jan 27, 2015 08:30 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
